Forums >> Community >> Newbies >> 3D View gone crazy - walls and floors etc missing from view?
0 Posts No Rating |
Hi all,
Somewhat new with Revit. Was working on my structure last night (and it was all good), but when I turned on my computer this morning and opened the file, half the walls etc are missing in the 3D view. There are no filters, nothing has been hidden, etc. i shut it down and it was all fine and visible, now half the building is visible, half missing. When I try to select a wall, I can't. I try to select several things and it all ends up invisible. It's just in the 3D view, everything's fine in every other view etc. Any ideas what on earth happened? I really need to fix this asap, any help appreciated!
Mat jsut be a corrupy view. Di you try remaking a 3D view? Also you dant say what Revit version but make sure you have all of your updates installed.
0 Posts No Rating |
Latest revit installed, no sign of updates needed. How do i "remake" the 3D view?
0 Posts No Rating |
Ok figured it out! Thanks for the speedy answer!
3 Posts No Rating |
I had something similar: isometric views displayed nothing. Plans, elevations, and perspectives were fine, but no isometric. Just an empty white screen. The fix was to audit the model when opening.
Floors and walls being transparent in 3D view |
Thu, Nov 12, 2020 at 2:52:53 PM
11
Floors show in all Views but 3D |
Sun, Jul 22, 2012 at 5:40:25 PM
how are joined beams and floors in 3d view? |
Mon, Jun 27, 2005 at 6:54:41 AM
My walls are missing in a view |
Wed, May 7, 2014 at 9:10:05 AM
missing walls |
Wed, Dec 10, 2008 at 2:27:52 PM
Members: | 2115752 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
