62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Andersen Windows
Thu, Mar 9, 2006 at 1:01:39 PM | Andersen Windows
mtbrider24
Has anyone tried using the Andersen Window families that are available? I downloaded a few different ones and noticed when I inserted it into my model that the sill heights and head heights were off. (ie: to set the window at the right height visually in my model, I'd have to set the sill height at 6'-8" which esentially pushes my head height to say 10'-8" for a four foot high window.) I could make this work visually for the model but I know it will create problems when I want to generate my window schedule. If I edit the window schedule to the correct heights, it will push my model windows down. Any ideas on how I can fix the problem? Is there something in those particular window families I need to modify? If so, what and how? I looked at the families and can't tell if there is a formula or something else that is setting the origins off or if I can change something in my model to make them work. Thanks ahead of time for any input. eric
Thu, Mar 9, 2006 at 1:21:07 PM | RE: Andersen Windows
mtbrider24
OK - I finally just figured it out. There is a head height reference plane in the family that has a "defines origin" parameter under properties. It was checked and it apparently should not be. After I unchecked it and reloaded the family, it worked fine. FYI eric
Thu, Mar 9, 2006 at 1:25:51 PM | RE: Andersen Windows
BS0450
BS0450 Avatar
3 Stars: 1 Votes
Awsome, I was having the same problem. Thanks!
Tue, Apr 25, 2006 at 10:15:51 PM | RE: Andersen Windows
ICON
5 Stars: 3 Votes
I'm in a situation with design options. While editing an option, I inserted AW dbl hungs, unchecked the "defines origin" parameter and placed windows at proper window height, in this case 7' 11". Now when I end the edit session my windows toggle back and forth between the original incorrect head height from the original main model and the correct head height from the design option. When I go to edit design option, the windows are at the correct height and when I end the edit the windows show at the incorrect height. It's kind of "fun" to watch it, but only because I don't know what happened. Do I need to undo to the point before the design option was created, uncheck the "defines origin" parameter" and then recreate the design option, or is there another way?? Post edited on 2006-04-25 22:21:18 Post edited on 2006-04-25 22:21:31
Wed, Mar 3, 2010 at 8:24:35 AM | BS0450
jarosa
jarosa Avatar
4 Stars: 5 Votes
Quoting BS0450 from 2006-03-09 13:25:51
"Awsome, I was having the same problem. Thanks!"
Me too. Thanks MTBrider24 (2006 Post!!!)
Andersen double hung windows
Sun, Jan 18, 2009 at 4:45:24 PM
How to make double or tripple Andersen double-hung windows
Sun, Jan 11, 2009 at 12:38:51 PM
New Windows in New Walls
Tue, Dec 18, 2007 at 2:30:02 PM
2011 Andersen Windows can't get them to work
Fri, Sep 23, 2011 at 12:28:45 PM
Incorrect color Andersen wdw in shaded elevation w/ correct color in 3d views
Fri, Jul 6, 2018 at 3:37:32 AM
Page generation time: 0.4325
