51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Changing the wall reference of a ladder family in revit
Tue, Oct 7, 2014 at 6:12:30 PM | Changing the wall reference of a ladder family in revit
AnaVg
I'm new at designing parametric families, and I need to design a specific ladder:
Problem: I designed a parametric ladder around a 152.4mm (6") wall, and the moment I try inserting it in a thicker or thinner wall, only one element attatches to the face of the wall while the rest attatches to the wall's centerline.
Goal: I'de like to change the original reference to my whole ladder so that I don't have to start it again from zero.
Help? Suggestions?
Thanks in advance.
Wed, Oct 8, 2014 at 8:15:06 AM | Changing the wall reference of a ladder family in revit
Suggestion... Download the families guide from the autodesk site to help you understand how to build families.
If this is truely a wall hosted element (not sure when you write "a 152.4mm (6") wall") .  The wall hosted family's wall can be adjusted in thickness.  Typically, you should flex this wall to see if your family works correctly at other thicknesses.
I like to build wall based families around a reference plane that is well away from the wall initially.  Before closing the family, I move this plane back to the wall face.  The reason I do this is that Revit will create relative locations for you element based on the wall.  That is what apparently happened in your case.  You can still probably fix your family by defining where the erooneos attachment iends (connection).
Wed, Oct 8, 2014 at 1:02:55 PM | Changing the wall reference of a ladder family in revit
AnaVg
Thank you WWHub, it seems like the way to go. I'll have to check it out later since I'm having some delivery date issues at the moment. For this project's sake, I'll just have to make it volumetric and non-parametric.
Thanks a lot!
Family array breaking
Fri, Jun 1, 2012 at 9:01:45 AM
6 ft step ladder
Tue, May 15, 2012 at 1:17:22 PM
Roof ladder family?
Sun, Apr 19, 2015 at 4:32:46 AM
Family Screwing up in 1 Project
Thu, Jan 31, 2008 at 4:16:09 PM
Revit 2015 - Ladder Cable Tray
Mon, Feb 29, 2016 at 5:05:15 PM
Page generation time: 2.1534
