88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DWG export: room tags to different layers
Tue, Oct 7, 2014 at 5:56:47 AM | DWG export: room tags to different layers
ccarlsson
Hi,
Is it possible to assign different room tags to different layers when exporting to DWG? I've been looking in to subgategories and layer modifiers but can't really get it to work. Any ideas?
Thanks in advance,
Christopher
Tue, Oct 7, 2014 at 7:27:53 AM | DWG export: room tags to different layers
All annotative elements (text, dimensions, tags, detail lines, filled regions, detail elements) are placed in the view workset and can not be transfered.
In the default setup, Revit exports room tags to: A-AREA-IDEN - but you can change that.
Edited on: Tue, Oct 7, 2014 at 7:36:28 AM
DWG Export Setup for particular layers?
Wed, Jul 24, 2013 at 3:22:41 PM
How to Export Room Tag Names and Areas to different layers in Autocad?
Mon, Dec 30, 2013 at 2:03:49 PM
dwg export duplicate layers
Tue, Dec 3, 2013 at 3:29:32 AM
REVIT 2013 - Export DWG Layers Text File Location
Fri, Aug 3, 2018 at 4:44:52 PM
DWG Export- Does Room Data get exported as well?
Fri, Nov 14, 2014 at 11:49:00 AM
Page generation time: 1.0147
