60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> dimensioning opening height of linked file
Mon, Oct 6, 2014 at 5:06:56 AM | dimensioning opening height of linked file
eassinck
Working in Revit 2015 i was wondering if it is possible automatically dimensioning the opening height (wall openings, doors or windows) in a linked file. At the moment i can't get it to work.
In the original file (existing building) the opening height is reported perfectly in liniair dimensions in floor plans. But in the file where the existing building file is linked (Addition to the existing building) the height of the openings in the existing building are not displayed.
It would be a pity if i had to create by linked views just because i can't get the opening heigts of existing openings displayed in the floor plan.
Mon, Oct 6, 2014 at 9:08:30 AM | dimensioning opening height of linked file
3.5 Stars: 401 Votes
You could if you copy monitored the walls and doors.
This works like a tag does and you need to own the element.
Mon, Oct 6, 2014 at 9:49:46 AM | dimensioning opening height of linked file
eassinck
Thanks for the reply.
I tried using copy/monitor. Maybe it's the answer for relative standard projects but in my case it doesn't help me very much. When i try to copy/monitor a wall i get a ton of warnings like 'Rectengular opening doesn't cut its host'.
I think i know why. The existing building is an old monument and has quite a complicated build. Also there will be an extensive renovation of the exesting building. Existing openings are filled or expanded. New openings wil be created, sometimes effecting muliple walls or existing openings. Existing doors wil be renewed.
We used phasing for that and all in all it wasn't easy to get everything exactly as we wanted it to be. We succeded but with lots of effort.
I don't know if using phasing the wrong way (i don't think soWinking may be the cause all the warnings but i suspect that the complexity of the existing building and all of the alterations may be a problem using copy monitor. Correct me if i'm wrong.....
Wall opening family in slanted wall
Thu, Sep 6, 2012 at 2:50:57 PM
Dimensioning with linked DWG files
Sat, Nov 12, 2011 at 4:20:06 PM
Linked Revit File - Objects Offseting
Thu, Apr 16, 2009 at 10:24:51 AM
Dimensioning across multible linked files
Fri, Jan 15, 2010 at 10:33:16 AM
Wall Openings - Changing Height
Wed, Jan 28, 2009 at 8:05:26 AM
Page generation time: 0.9861
