71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Generic Model Materials
Fri, Oct 3, 2014 at 12:52:13 PM | Generic Model Materials
kalin1
The material pattern for a generic model made of an extrusion shows in the model but not in plan view. Both model and drafting patterns have been tried, there are no overrides and the detail level is set to fine.
Does anyone have an idea how to make the pattern show in plan? Thanks!
Fri, Oct 3, 2014 at 12:56:15 PM | Generic Model Materials
If you are cutting the object, then there is a seperate cut pattern.
If you mean the top surface of an object, has there really been a material assigned to this surface?
Maybe a simple snip of your plan and the properties of the object would help.
Fri, Oct 3, 2014 at 1:18:05 PM | Generic Model Materials
kalin1
Thanks for weighing in, the cut plane is above the object so it should be showing the top surface. Attached is a screen shot of the object material properties.
Fri, Oct 3, 2014 at 1:49:02 PM | Generic Model Materials
OK ... so that is the material.   What is the object?
Fri, Oct 3, 2014 at 1:53:40 PM | Generic Model Materials
kalin1
These are the object properties. When in the Edit In Place mode for the object, the pattern shows up but it dissapears again after clicking Finish Model.
Wed, May 18, 2005 at 5:03:38 PM
CREATING A SCHEDULE FROM A GENERIC MODEL FAMILY?
Mon, May 11, 2009 at 11:49:38 PM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:18 PM
generic model cutting issue 2016
Sat, Aug 27, 2016 at 7:43:47 AM
Opening in Generic Model Standing seam roof
Mon, Aug 17, 2009 at 9:43:32 AM
Page generation time: 1.3848
