103 Users Online (102 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can't select gridlines
Fri, Oct 3, 2014 at 9:04:47 AM | Can't select gridlines
geraldrogers
I created a grid for my project and locked or pinned it. I can't remember exactly what I did to it but I am now unable to select it or edit it at all which I would like to do in one plan because the grid heads are at the wrong end of the lines. Any ideas?
Gerald Rogers
Revit 2015
Fri, Oct 3, 2014 at 9:23:24 AM | Can't select gridlines
Thread Post Kudo! #2
geraldrogers
Ah, I have it! I had select pinned elements turned off. Phew...
Gerald Rogers
Revit 2015
Fri, Oct 3, 2014 at 9:26:49 AM | Can't select gridlines
geraldrogers
While we're on grids though is there a way to change the grid bubble to the opposite end on multiple lines at once?
Gerald Rogers
Revit 2015
Fri, Oct 3, 2014 at 9:37:54 AM | Can't select gridlines
3.5 Stars: 395 Votes
Sorry, there is no way to do what you asked.
I just gave a lunch and learn here to remind folks to be careful when they first lay out their grids and levels because that determines the default location for bubbles in all views.   Grid heads and level bubbles are always placed on the ending point of your grid/level line instead of the beginning.  So if you do it correctly from the beginning, you will have fewer adjustments to make later.
Fri, Oct 3, 2014 at 10:00:46 AM | Can't select gridlines
geraldrogers
Actually I have discovered 'propogate extents' which enabled me to use the grid I had set up correctly and replicate this on the other levels.
Gerald Rogers
Revit 2015
dimensioning gridlines
Sat, Nov 4, 2006 at 10:27:59 AM
Gridlines
Fri, Aug 8, 2008 at 3:24:08 PM
Building Gridlines vs Underground Gridlines
Thu, Mar 17, 2011 at 1:49:59 PM
re-numbering gridlines
Wed, Mar 26, 2008 at 3:08:06 PM
Gridlines in front of Model / Linework
Tue, Jul 13, 2010 at 12:45:01 PM
Page generation time: 0.6557
