172 Users Online (171 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> schedule showing wall height
Fri, Oct 3, 2014 at 6:45:36 AM | schedule showing wall height
SteveB
3.5 Stars: 5 Votes
I am trying to make a material schedule sorting (concrete) walls by wall height. (concrete bidders price x linear feet of each certain wall height) Unconnected wall height" is a constraint that is displayed in the properties.  Not available as a parameter to display in a schedule.  I tried a calculated field (area/length) which gives inaccurate info especially on short walls due to the way walls are joined.
Is there a way?
Fri, Oct 17, 2014 at 10:10:56 AM | schedule showing wall height
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Believe it or not I don't think there is a way ! Walls can also be attached from their bottom or top to other elements and can have edited profiles. I seem to recall playing with this (more than once) and not coming up with a way to schedule wall height outside of  creating a project parameter (Manual Wall Height) and MANUALLY inputting each wall height which is perposterous. This would be very labour intensive and a huge undertaking but at the end of the day it would give you what you want but would not be parametric or automatic and would require baby sitting.
Fri, Oct 17, 2014 at 10:31:08 AM | schedule showing wall height
SteveB
3.5 Stars: 5 Votes
I didnt think so.  I tried to kluge it in by making a formul that divided the area of the wall by the length (since those 2 parameters are available) but it gives fractional results that are way off on short walls due the joining and beveling.
2015 wall height
Fri, Jul 10, 2015 at 9:17:03 AM
I can't see "Height" parameter value of Wall or Currtain Wall Schedule?
Thu, Apr 27, 2017 at 2:04:40 AM
scheduling height of irregular curtain wall panels
Sun, Mar 11, 2012 at 12:08:01 PM
Room schedule with ceiling height
Fri, Jul 13, 2007 at 11:01:43 AM
Wall Schedule showing Wall Assembly
Thu, Apr 29, 2010 at 1:26:28 PM
Page generation time: 1.6000
