61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Project Orientation
Thu, Mar 9, 2006 at 11:57:04 AM | Project Orientation
keene
How do I set true north? When I go to View > Orient, the options are greyed out. When i go to Settings>Manage Place and locations, the angle is greyed out. Where can I input this information so that I dont have to reorient(rotate) the model it self to get accurate sun studies?
Sun, Mar 12, 2006 at 12:09:22 PM | RE: Project Orientation
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. Hello Keene, I remenber all too well having this same frustrating problem. This is a little tricky and not documented well. In REVIT 8.1 do as follows: 1. Right click on the view name in the project browser. 2. Click Properties. 3. Set the Orientation to True North. 4. VERY IMPORTANT - Before you proceed, make sure you click your mouse into the (white) editing window where your model is to make it the active window. If your active window is still in the Project browser the next step will not work. Experiment and you will see what I mean. 4a. If you do not do step 3. the next step will not work or you will get a warning. 5. Go to >Tools > Project Position / Orientation > Relocate True north. 6. Click the start point and end angle to rotate. Tada ! After that all you have to do is repeat step 1,2,3 for each view you want rotated * Step 4 above is very subtle but will cause the 'greying out' of your orientation tools and stop you in your tracks as you haver seen. Now if you go to >Settings > Manage Place and Location > you will see the new 'Read only' angle that you rotated. You can find this Tutorial and many more REVIT Tutorials at http://www.dgcad.com Hope this helps, Daryl DGCAD www.dgcad.com
Sun, Mar 12, 2006 at 4:26:58 PM | RE: Project Orientation
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. Below is a direct link to the specific Tutorial on 'True North - Project North' http://www.dgcad.com/downloads/CADCLIP-TRUE-NORTH-PROJECT-NORTH.wmv Right click the link above and click "Save Target As..." to download the file to your desktop or share with others. DGCAD
Mon, Mar 13, 2006 at 8:11:03 AM | RE: Project Orientation
keene
fantastic! thank you.
North Point and project orientation
Wed, Nov 17, 2010 at 12:38:54 PM
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:07 PM
Functionality Bugs
Workflow & Implementation >> Chameleon
Mon, Oct 15, 2012 at 5:55:48 AM
Missing Orientation option (Project North/True North) in Properties Palette
Fri, Jan 29, 2016 at 11:23:52 AM
Linked Revit model not importing in the correct orientation
Fri, Nov 20, 2015 at 4:00:35 AM
Page generation time: 1.2787
