30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Mirrored Families
Wed, Oct 1, 2014 at 9:28:03 AM | Mirrored Families
blue442
blue442 Avatar
Ok - I have a complicated family I’ve created for tilt concrete panels.  The family has 2 doors, one on the left, and one on the right.  Often we flip the overhead door with a 3’-0” door.  And flip it left to right.  So we just mirror it.  The family was setup so it could be mirrored (and works correctly).  But I have no idea how to tell if it is mirrored once I have mirrored it.  Is there something I’m missing here?
Is there a way to include something inside the formulas to inform me if it is mirrored?
Thanks.
Wed, Oct 1, 2014 at 10:02:59 AM | Mirrored Families
I don't see any way to report that short of two seperate families and then a mirror would defeat that.
Wed, Oct 1, 2014 at 10:07:11 AM | Mirrored Families
blue442
blue442 Avatar
Bummer.  Ok, i was hoping you or someone else would have had a thought on that.
All of my parameters were setup with "Left" and "Right" in the name.  when you mirror it, it gets confusing since the right is now the left.  Not a really big deal since you can easily figure it out by togging a door on or off.
Thanks!
Wed, Oct 1, 2014 at 9:27:34 PM | Mirrored Families
CDWdavid
5 Stars: 5 Votes
You may try to add a mark in your family elevation using invisible lines.
That mark can tell you that if the family has been mirrored or not, it cannot be reported but at least you may check on elevations.
An invisible line can be seen in family, but not in project.
However, when you pick that family in a project, you will see those invisible lines as a blueish image.
Thu, Oct 2, 2014 at 12:49:16 PM | Mirrored Families
blue442
blue442 Avatar
that's a good tip.
thanks!
Can you create mirrored walls (shiney reflective ones) with Revit?
Tue, Nov 25, 2008 at 12:07:26 PM
Curtain Panel Unexpectedly Mirrored in Project
Fri, Feb 26, 2016 at 1:22:33 PM
Model Pattern in Mirrored Groups
Fri, Apr 17, 2009 at 5:23:13 AM
Void Component - in group moves when mirrored
Fri, May 9, 2014 at 8:13:50 AM
Nested wall family not scheduling correctly
Thu, Jul 21, 2011 at 10:18:50 AM
Page generation time: 0.6716
