30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Angled Door & Window Codes
Tue, Sep 30, 2014 at 9:13:21 PM | Angled Door & Window Codes
raja15
Hi there.
I'm currently using Revit 2014 on Windows 7.
Just a heads up I've already searched the forums but haven't found an answer to my question.
I'm currently working on a project which (in plan view) has standard walls at 90º horizontally & vertically.
This project also has  a section of walls which (in plan view) are at 30º & 60º.
I'm finding that I'm unable to get my door & window codes to sit parallel to these 30º & 60º walls. (see example attached)
Is there a way to get this to work? Or will I need to create a separate family for these codes to use on the angled walls.
Thanks in advance.
Tue, Sep 30, 2014 at 9:27:21 PM | Angled Door & Window Codes
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
In the tag family, check ‘Rotate with Component’ in properties.
Wed, Oct 1, 2014 at 2:31:28 AM | Angled Door & Window Codes
raja15
Thanks pijpiwo !
Much appreciated
Angled Window (angled jambs on both sides)
Wed, Apr 13, 2011 at 9:48:15 PM
Window with angled sill
Fri, Nov 16, 2012 at 10:49:58 AM
Angled window opening in plan view
Thu, Aug 15, 2013 at 2:18:13 PM
11
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:29 AM
Window & door tag formatting
Tue, May 25, 2010 at 9:27:08 AM
Page generation time: 1.3417
