67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> REVIT 2014 FLATTEN PLANE
Tue, Sep 30, 2014 at 5:32:19 AM | REVIT 2014 FLATTEN PLANE
online2000
online2000 Avatar
hi all
I have a query at the office about making mass warped planes- flattened- in other words, i wans to take a four sided warped plane  and extend the nodes so that i get the four nodes to lie on the same plane-
this is to avoif a waprd plane converting to two triangles!
is there  asmart way to do this without a VOID cut operation? this seems to be easily done in SKETCHUP but not so much in REVIT
thanks
E
eli
Tue, Sep 30, 2014 at 7:04:52 AM | REVIT 2014 FLATTEN PLANE
3.5 Stars: 401 Votes
You would be better off to cut your mass with a void.
Tue, Sep 30, 2014 at 7:54:36 AM | REVIT 2014 FLATTEN PLANE
online2000
online2000 Avatar
not very satisfactory... the idea woudl be to try form four sided flat planes that can be manipulated easily by some snap system- but instead- i woudl have to cut each time to update
eli
Tue, Sep 30, 2014 at 10:19:52 AM | REVIT 2014 FLATTEN PLANE
online2000
online2000 Avatar
this particular operation is very simple in sketchUP
STEP 1- i have these two triangles (right side of the box)
step 2- i now stretch one edge so that it becomes one plane
Tue, Sep 30, 2014 at 12:45:26 PM | REVIT 2014 FLATTEN PLANE
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I’m not sure if that’s what you need, but you can create a form with ref lines and shape handle points (generic model adaptive family template), so each point can be moved independently in every direction. Number of points is up to you. Hope it helps.
Wed, Oct 1, 2014 at 2:10:58 AM | REVIT 2014 FLATTEN PLANE
online2000
online2000 Avatar
not really
we are trying to form a complex geometry that relies only on 4-sided planes instead of the usual trianlges.. this needs to of course use flat planes and not as REVIT gives us the warped hyperbolic planes
the normal stretch grips would be fantastic - but once i have used a VOID commend... it warps the plane again...
eli
Wed, Oct 1, 2014 at 7:11:26 AM | REVIT 2014 FLATTEN PLANE
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Instead of solid mass, add vertical edges (lines) and create surfaces. When you stretch a plane, it will not twist.
Wed, Oct 1, 2014 at 9:12:54 AM | REVIT 2014 FLATTEN PLANE
online2000
online2000 Avatar
as mentioned- i want 4-sided planes - not triangles
eli
Handrails Flatten When Extended
Fri, May 29, 2015 at 1:11:10 PM
Reference Plane Issues
Tue, Mar 10, 2015 at 9:19:15 AM
How to import sketchup models into revit 2014
Fri, Aug 5, 2016 at 9:29:15 AM
Tall Objects Above Cut Plane: Bleachers
Wed, Aug 20, 2014 at 10:16:06 PM
RevitRubyShell Revit 2014
Fri, Jun 7, 2013 at 7:10:05 AM
Page generation time: 2.0199
