38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Link Revit/ BIM File
Sat, Sep 27, 2014 at 9:00:01 AM | Link Revit/ BIM File
alihusnain95
Hi There! i have built a model but i need i need to put details of wall (sound & fire insulation block, i got BIM revit file from manufacturer of product, i linked the revit file and it has been imported into my project with its origional drawn size and i am unable to change size to put that block instead of general wall....any help?
Regards
Ali
Wed, Oct 1, 2014 at 11:56:47 AM | Link Revit/ BIM File
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I realize that you are struggling with the language but this question makes no sense what so ever.
Wed, Oct 1, 2014 at 3:05:01 PM | Link Revit/ BIM File
alihusnain95
Hello Dgcad! I am sorry if u didnt understand my question, I have imported a BIM (of sound/wall block) from manufacturer website, i have linked that file into my project, but that wall block doesnt change size to use into project ...how can i use that wall block to size of my choice ?
Hope you understand...
Regards
Ali
Wed, Oct 1, 2014 at 3:38:20 PM | Link Revit/ BIM File
Walls are walls.... Although you may define them as having a block structural core, you don't use components to create Revit walls.
Giving us a link to this product would have helped us to understand what it is.   I am assuming it is like concrete block but assuming is a poor substitute for you not explaining.
Wed, Oct 1, 2014 at 4:23:51 PM | Link Revit/ BIM File
alihusnain95
hello WWhub! I have attached th file for you to view,
It is kind of partion to use as a wall, Britishgypsym, its 122 thick and company did full details of this block partion, i just wants to link this to revit, which i did successfully, then i wants to use this sound/fire resistant block into my project  wherever i want.
when you see the attach BIM file you should be able to understand my query,
thanks
Ali
Wed, Oct 1, 2014 at 6:03:45 PM | Link Revit/ BIM File
Roger1w
Don't link the file drag and drop it in.
Then select from the wall drop down.
BIM 360 Link Issues
Wed, Sep 12, 2018 at 12:10:51 PM
Link Revit File
Tue, Dec 4, 2018 at 11:59:20 PM
RISA/Revit Link
Wed, Sep 10, 2008 at 2:17:38 PM
Revit is now 4D BIM, or is it?
Tue, Apr 29, 2008 at 7:27:51 AM
Can't Remove File from BIM 360
Wed, Apr 10, 2019 at 8:59:17 AM
Page generation time: 2.9633
