45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> monolithic stair join at floor slab
Wed, Sep 24, 2014 at 8:57:47 AM | monolithic stair join at floor slab
ArchimediaIE
Hi - I have a number of stair runs that I am trying to connect with landings and the floor slabs - The problem I am having is that at the start of each run - the monolithic underside doesnt connect properly to the Floor slab or landing - it on;y works correctly at the end of each run- I can't use multi run stais as the risers differ for each run as it's an existing concrete stairs. I am usinf Revit 2014.
Any advice would be appreciated
Wed, Sep 24, 2014 at 9:45:24 AM | monolithic stair join at floor slab
Try using - "begin with a tread"
Wed, Sep 24, 2014 at 9:54:18 AM | monolithic stair join at floor slab
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Component stair:
Select stair->edit stair->select stair->extend below riser base (properties). Apply negative offset.
Stair by sketch:
Select stair->edit stair->edit type->extend below base. Apply negative offset.
Wed, Sep 24, 2014 at 10:03:56 AM | monolithic stair join at floor slab
ArchimediaIE
thank you both - WWhub - its a conc stairs and i can't find the a 'begin with tread'
however Pijiwo, "extend below riser" worked beautifully - really appreciate your help, that was bugging me for hours.
Regards
Peter
Wed, Sep 24, 2014 at 10:22:31 AM | monolithic stair join at floor slab
Sorry - I should have said "Uncheck begin with a riser" .   Then you would also have had to set "Extend below base".  This needs to be a negative.  See image.
We rarely do we extend the bottom because our precast stairs have to sit on something.
Wed, Sep 24, 2014 at 11:30:36 AM | monolithic stair join at floor slab
ArchimediaIE
Excellent thanks again!
regards
Peter
how to connect monolithic stair to f.c. slab
Fri, Apr 17, 2009 at 2:38:26 PM
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:19 AM
13
monolithic stairs
Sun, May 16, 2010 at 6:33:13 AM
Ye Olde Curved Monolithic Stair
Wed, May 29, 2013 at 8:31:15 AM
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:25 AM
Page generation time: 0.6829
