72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> mirror showing as black in realistic visual style
Tue, Sep 23, 2014 at 6:06:27 AM | mirror showing as black in realistic visual style
Spirited
have made a mirror in editor (simple extrusion - face based), used 'mirror' material.  Load into project, rendered a camera shot - yep works well - reflections, depth, bounce etc all good.  Happy camper.  Would like to change the 'realistic' visual style of the mirror from black to something else (anything).  Help appreciated.
Family editor - material mirror.  Checked material appearnace, RGB settings, show as rendered.
Project: manage -> materials.  checked material all appears the same ie.  no overriding of family 'mirror' material by project 'mirror' material as they are the same.
Even went in and checked the acceleration on the video card (desperate/sinking/clutching at anything), even applied a change to the transparency to make sure I was working on the right object (yes I was/am).
this question has appeared elsewhere but doesn't appear to have a response.
Using Revit2014.
Fri, Oct 17, 2014 at 10:21:46 AM | mirror showing as black in realistic visual style
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Does it 'render' properly ?
Fri, Oct 17, 2014 at 1:48:08 PM | mirror showing as black in realistic visual style
ScubaMan
Is there another mirror on the other side of it created the infinity mirror effect? If so Revit will only do so many reflation before rendering it as black.
Walkthrough in realistic view, not rendered
Wed, Aug 27, 2014 at 12:00:38 PM
Having problem with realistic style mode in Revit Architecture 2012
Wed, Jun 22, 2011 at 8:04:36 AM
Realistic Trees in Site Plan
Fri, May 6, 2016 at 3:29:32 PM
Revit graphics, problem with Realistic and Shaded Visual style
Wed, Nov 28, 2012 at 3:56:35 AM
Realistic Style Help
Mon, Aug 30, 2010 at 8:41:35 AM
Page generation time: 1.3751
