92 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> Gaps between Subregions
0 Posts No Rating |
Hi,
I am new to RevitCity and I apologise if this question was answered here, but I cannot find any sufficient answer to this. I am drawing subregions in topography.I know that the lines cannot overlap or be on top of each other to create subregions next to each other.
1. how will I get rid of this ugly gaps between subregions (see the picture)
2. when i start drawing second subregion (close to the first one), I cannot see the lines of the first one, which I am trying to avoid overlap, so I am just guessing where I drew it approximately. (too many lines for topography and CAD site plan linked to revit, so I cannot see subregion lines maybe or does it really disappear while sketching second subregion?)
I would be greateful for any help. Thank you.
Thank you
Petra
You are not completely correct about the lines not overlapping. I use the same process here as I do with pads when I have two side by side. Edit the sketch of your first region and pick the lines that will form part of your adjacent region. Copy those to clipboard and finish the sketch. Now start your next region and paste aligned same place. Add the rest of the linework and finish your sketch.
0 Posts No Rating |
Thanks for your reply. I will try to do it this way. ![Smile](/images/smiles/smile.gif)
how to view a toposurface with thickness in a elevation ou in a 3d view?? |
Thu, Jun 16, 2011 at 1:07:26 PM
Gaps is walls and corner [ 1 2 ] |
Thu, Jan 12, 2017 at 12:19:52 PM
15
Tagging Subregions in Topography |
Mon, May 21, 2012 at 7:45:10 AM
Subregions on Topography Take Ages to Process & Regenerate. |
Mon, Mar 23, 2015 at 7:24:12 AM
Building Pads and subregions |
Fri, Sep 16, 2005 at 5:25:43 PM
Members: | 2016995 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
