Forums >> Revit Building >> Technical Support >> Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
0 Posts No Rating |
No matter what I am working on in my project, the modify schedules/quantities tab is always lit up, like I'm in the middle of modifying a schedule. The problem is, I'm not. Example, if I try to draw a wall, I go to the Architecture tab, select wall, and it automatically flips back to modify schedules tab. The modify walls is also lit up at this point, but I have to select it at the top to get off the modify schedules tab. I don't know how this happened, but it's there even if I close the program and reopen with a new project. Does anyone know how to fix this problem? I feel like it should be easy to fix, but I can't seem to figure it out.
Thank you!
Jennifer
What updates do you have installed?
0 Posts No Rating |
Has this issue been resolved? I'm having the same problem here...
0 Posts No Rating |
Not resolved yet.
Edited on: Tue, Nov 25, 2014 at 11:50:47 AM
Again ... what updates do you have installed. Give us the latest number - not just a yes.
0 Posts No Rating |
Go to Opotions > User Interface > Toggle off Display the contexual tab on selection at the bottom
How to include the Level parameter in Wall Schedule & quantities |
Mon, Sep 25, 2006 at 7:34:35 AM
RAC 2012 Modify Tab on Ribbon |
Thu, Jul 5, 2012 at 10:27:41 AM
Revit 2014 schedules... where did the Show button go? |
Mon, Dec 16, 2013 at 2:18:43 PM
Drafting View/Schedules for quantities |
Thu, Mar 29, 2012 at 9:17:18 AM
Schedules/Quantities |
Tue, Dec 20, 2005 at 10:05:21 AM
Members: | 2101683 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
