Forums >> Workflow & Implementation >> API & Third Party Apps >> Siteworks add-in
This is a free add-in for subscription based users.
http://www.cadgroup.com.au/community/blog/cadblog/index.php?showentry=478
Site Designer Extension for Revit 15 allows users to: “You can model alternatives for mass grading, building pads, streets, sidewalks, parking lots, and retaining walls all within the Revit environment. More easily convert a sketched line into a street, sidewalk, curb and gutter, retaining wall or parking lot in the model. You can manipulate Site Designer components using editing tools to change their location, elevation, grade or geometry, and Site Designer automatically updates and maintains the underlying toposurface”.
31 Posts No Rating |
A helpful hit.
If you are using this tool and want to hit the green check mark to finish the command right click and hit cancel. Don’t ask me why but that’s how it works. There is no Green Check Mark
Wow. Sitework is a weak point of Revit. I look forward to trying this.
50 Posts No Rating |
I have been trying to play with it, but no luck.
my topo's are created from dwg links. Does this make a difference? I can only find reference to civil files.
siteworks revit |
Sun, Nov 17, 2013 at 4:45:50 PM
SITEWORKS FOR REVIT - Tutorials |
Thu, Oct 9, 2014 at 2:20:57 PM
Eagle Point Siteworks Revit Addin Reviews |
Thu, Jan 16, 2014 at 11:11:48 PM
Revit Add-Ins & Extensions |
Wed, Mar 2, 2011 at 4:39:16 PM
G'day everyone |
Fri, Aug 26, 2011 at 11:52:11 AM
Members: | 2099108 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
