39 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> move Room Tag to different level
Thu, Sep 18, 2014 at 4:39:19 PM | move Room Tag to different level
bus03
Hello,
The house I'm designing is a split level, and so I need my room tags to all appear in the same view.  Right now, if I tag rooms on one level, they don't appear in the floor plan of the main level.  I know there's a way to do it, but I can't remember.
Thanks
Thu, Sep 18, 2014 at 11:09:18 PM | move Room Tag to different level
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
The room tags are view specific. As long the room objects on the upper level are cut by the cut plane of the main level, you should be able to tag these rooms on your main level 1 plan.
Thu, Sep 18, 2014 at 11:21:09 PM | move Room Tag to different level
bus03
Yes, that worked. I knew it was simple. Incidentally, if you make a room on level 2 but don't name it, then name it on level one, it updates in level 2.
Thanks for the reply!
Adding a Numerical Level Parameter to a Room Tag
Mon, Jul 23, 2018 at 10:53:59 AM
TAG ROOM SELECTING ROOM TAG IN FLOOR BELOW
Fri, May 1, 2015 at 8:24:47 AM
Move room area to other level
Mon, Jan 24, 2011 at 1:03:55 PM
Room tag not showing in only one room.
Fri, Oct 1, 2021 at 11:04:59 AM
Room Tag With Ceiling Offset from level, or Ceiling High
Sun, Mar 8, 2009 at 11:03:00 PM
Page generation time: 0.8799
