105 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> PNG- TRANSPARENCY- COLOR SCHEME
Thu, Sep 18, 2014 at 8:48:05 AM | PNG- TRANSPARENCY- COLOR SCHEME
HKicsak
I am attempting to have tenant logos on our floor plans. I have saved all of the logos as PNGs with a transparent background and when I insert them on the plan, they work fine. The color scheme applied to the floor plan shows through the background as desired on the screen.
The problem comes when I go to print- to printer or PDF- and the background of the images is no longer transparent but white. Has anyone else had this issue? Is it related to the image or the color scheme?
I have tried saving the PNG in multiple ways, 32bit, 16bit, etc and there is no change. This happens in both 2014 and 2015, all updates installed. The color scheme uses solid fills for all values, PNGs all set to foreground.
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop?
Thu, Sep 18, 2014 at 12:47:19 PM | PNG- TRANSPARENCY- COLOR SCHEME
HKicsak
SOLUTION: There was a view template applied and in that view template only the color scheme was set to Foreground instead of Background. Changing it to Background made the PNG backgrounds transparent again.
Didn't even know that option existed for color schemes!
Thu, Sep 18, 2014 at 1:43:52 PM | PNG- TRANSPARENCY- COLOR SCHEME
Good post - thanks for sharing the solution
Sun, Sep 30, 2018 at 10:09:50 PM | PNG- TRANSPARENCY- COLOR SCHEME
AyyLmao
I still get this problem with no template applied in 2017 and 2018
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Color Scheme Problems
Tue, Jun 26, 2007 at 11:53:16 PM
ZONE COLOR SCHEME
Thu, Sep 30, 2010 at 6:18:26 AM
Page generation time: 2.0982
