54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Custom modern railiings revit 2009
Wed, Sep 17, 2014 at 9:06:55 AM | Custom modern railiings revit 2009
js420
Yes, Revit 2009 - I am behind the times.
I am trying to make railings like these (sketchup 3d image sttaced) and I am not sure how to go about them - the frame is a steel pipe, there are no balusters, the posts are attached to the outside of the stringer. The horizontals are cable rail.  I want to use the same railings for both the stairs and the deck rails. Any help on how to proceed will be much appreciated !
Thu, Oct 16, 2014 at 11:26:37 AM | Custom modern railiings revit 2009
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You can't make that railing.
Fri, Oct 17, 2014 at 4:58:29 AM | Custom modern railiings revit 2009
ronmalit
5 Stars: 3 Votes
WOW
SORRY to butt-in....and sorry to say that this is POSSIBLE...
see attached file, you can just modify the start and end post of those railings
and if (just if) you are not able to do that, you can always use generic model family and use sweep and sweep blends to create your railings as if you are doing it in sketchup.. but with parametric lengths and angles for deck or stair rails
** dont be mad, i dont have much... i am homeless
Modern furniture
Mon, Jul 27, 2015 at 10:25:57 PM
HighTower Modern Furniture Revit Families
Thu, Oct 4, 2012 at 4:08:31 PM
modern home design
Mon, Jan 26, 2009 at 3:43:11 PM
MODERN WALL TYPES IN REVIT
Wed, Jun 4, 2014 at 8:35:25 AM
custom light fixture, Revit 2009
Fri, Mar 11, 2011 at 9:28:44 AM
Page generation time: 2.1776
