79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> creating a family room
Wed, Mar 8, 2006 at 11:17:59 PM | creating a family room
dvsone78
For school my teacher is very adamant about using the parametric part of Revit. You can�t create walls in a family only extrusion and so I do. but I need the center line of the wall to move with the out side walls accordingly so that it becomes thicker also I need when I move an exterior extrusion for the perpendicular walls to move with it you know get longer or shorter depending. Spent about 3 hours trying to make this work but haven't had any luck. This is kind of an independent study course and the teacher doesn�t know enough to make it happen but wants me to figure it out. Any suggestion, other then Autodesk�s Revit training.
Thu, Mar 9, 2006 at 1:58:56 AM | RE: creating a family room
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Why would you want to create a whole room as a family? If you absolutely must do so, make the family without the walls and add instance parametrics to reference planes. Then draw your walls in the project and load the family in, then drag its length a width to match the room and lock them to the walls. Hopefully, when the walls move the family should flex... Is this what you're after?
Family Schedules going room-by-room
Wed, Jan 22, 2020 at 12:52:54 PM
Room Bounding Families
Wed, Mar 31, 2010 at 5:35:10 PM
Editing Room Label / System Family
Sun, Jan 31, 2010 at 7:32:44 PM
Creating Room Data Sheets
Wed, Aug 24, 2011 at 10:34:56 AM
Room Dimensions in Tag Family
Sun, Aug 31, 2008 at 9:23:36 PM
Page generation time: 1.1096
