121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> elevation split
Mon, Sep 15, 2014 at 10:11:04 PM | elevation split
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
hey guys I need to split my elevation marker and take it to the edge of the building for the ground line. Problem is it then cuts through my eave. Cant do a plan region is there something else I can do to fix this?
Thanks again!
Revit 2018........
Mon, Sep 22, 2014 at 6:52:36 PM | elevation split
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
bump...
Revit 2018........
Mon, Sep 22, 2014 at 11:09:46 PM | elevation split
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Crop your ground elevation view from the floor level up, or use any other established horizontal line for cropping. Use edit crop tool so you can snap to the level line. Create another elevation (or section) that clears the eaves and crop it from the floor level down. Put both views on the sheet and align them together.
Tue, Sep 23, 2014 at 8:17:18 PM | elevation split
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
That only way? I just ended up drawing it with line tool...
Revit 2018........
Split a an elevation marker up for mulitple sheets
Tue, Oct 4, 2016 at 2:29:35 PM
Level Split
Wed, Feb 1, 2012 at 4:04:32 PM
split segment on interior elevation view callout?
Tue, Sep 13, 2011 at 3:32:41 PM
Elevation Split
Thu, Feb 15, 2007 at 8:44:39 PM
Splits
Sun, Jan 30, 2005 at 9:30:04 PM
Page generation time: 0.6761
