34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Any way to automaticaly find room boundaries to make finishing floor?
Mon, Sep 15, 2014 at 6:59:25 PM | Any way to automaticaly find room boundaries to make finishing floor?
yushi
I may have missed something, but with the Room command, revit easily finds boundaries of the room. but How can I easily find
the boundaries to draw a floor? I always trace the edges, around the doors,... manualy.
thanks
Mon, Sep 15, 2014 at 10:02:17 PM | Any way to automaticaly find room boundaries to make finishing floor?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I’m not sure what is that you’re trying to achieve. Could you provide some more details or/and screen shots?
Mon, Sep 15, 2014 at 10:09:01 PM | Any way to automaticaly find room boundaries to make finishing floor?
yushi
ok. I want to draw outline for a Carpet Floor. I should go through all the corners zoom in and out to draw the floor outline.
Is there anything like Bpoly command in Autocad which can automatically find the boundaries of a room and then use that
as the outline of the floor?
Tue, Sep 16, 2014 at 1:50:46 PM | yushi
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting yushi from 2014-09-15 22:09:00
Not that I know of, but when in the floor sketch mode, instead of drawing lines, you can choose Pick Walls or Lines option to speed up the process. You still need to however, do some 'manual labor' around the doors.
Wed, Sep 17, 2014 at 8:13:12 AM | Any way to automaticaly find room boundaries to make finishing floor?
When doing the sketch, just use the pointing tool and don't zoom in!  You may have to trim some lines.
If your space is really crazy, create an automatic ceiling.  Pick the ceiling to edit and copy the sketch to your clipboard.  Now paste the sketch in what you are creating in plan.
Wed, Sep 17, 2014 at 3:27:18 PM | WWHub
yushi
Quoting WWHub from 2014-09-17 08:13:11
That was a very nice idea!
it worked
finishing problems
Tue, May 17, 2011 at 6:05:42 AM
room tag floor/wall/ceiling finishing
Mon, May 31, 2010 at 9:59:07 AM
editing room boundaries [ 1 2 ]
Thu, Oct 5, 2017 at 7:21:20 AM
17
wall floor finishing joint
Mon, Nov 23, 2009 at 4:56:31 AM
Room boundaries woun't properly display
Tue, May 15, 2018 at 3:08:15 AM
Page generation time: 1.7234
