37 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Revit color scheme issues?
Revit 2012
I have created a Department color scheme linked to the Rooms.
When I change the colors in the dialogue box they change in the plan but don't change in the legend. This is really frustrating rendering color schemes un-usable.
See attached image.
If anyone has any advice let me know. I have used a lot of differenrt versions of revit and have not run into this problem.
2 Posts No Rating |
Right in the help file:
If the color fill legend that displays does not reflect the color scheme that you want to use, do the following:
- In the drawing area, select the legend.
- Click Modify Color Fill Legends tabScheme panelEdit Scheme.
- In the Edit Color Scheme dialog, select a different color scheme from the list, and click OK.
You can also create a new color scheme in this dialog. For more information, seeCreating a Color Scheme.
*just noticed you said it was Revit 2012, don't know if this also works in that version*
Edited on: Tue, Sep 16, 2014 at 6:48:40 AM
Thank you for the reply. I think it might be a bug with 2012. The colors don't even match in the ledgend from the get go. A room will be yellow and the ledgend shows green.
This person had the same problem but never had any responses.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=29756
Let me know if anyone has a fix?
Color Scheme Legend Issues |
Mon, Dec 1, 2014 at 6:26:38 AM
color scheme disappear |
Fri, Sep 24, 2010 at 7:49:22 PM
DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011 [ 1 2 3 ] |
Sun, Jan 13, 2013 at 11:44:50 AM
30
new color scheme entry error |
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Problems |
Tue, Jun 26, 2007 at 11:53:16 PM
Members: | 2019245 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
