101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Underground Building Issues
Sun, Sep 14, 2014 at 11:01:48 PM | Underground Building Issues
ycpbruhbruh
Hi,I was wondering if it is possible to create something like the Archigram "Mound" Project in Revit 2014. I can make building pads to topograhy so that the building can be "trenched", however, it cannot make a topographic-like hill as a roof cover. Is it possible to do this?
Thu, Oct 16, 2014 at 11:25:21 AM | Underground Building Issues
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
As a 'roof' object you can't create a contoured surface. Only planar surfaces.
Fri, Oct 17, 2014 at 1:19:19 PM | Underground Building Issues
From the similar threads - Read Typhoon's response:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=11258
This user is online
Fri, Oct 17, 2014 at 1:51:16 PM | Underground Building Issues
zsmith3
Sometimes I make an 'earth floor' which is just floor made out grass or earth material (you could even layer them). It's not accurate in sections, but if you're attempting to render something like this it can be useful. Just modify sub-elements of the floor and elevate them where they need to be. The reason for using a floor is because a building pad can't cut it (a shaft still can).
Fri, Oct 17, 2014 at 1:55:34 PM | Underground Building Issues
zsmith3
Sorry, didn't read dgcad's response - same thing applies to floors
Building Gridlines vs Underground Gridlines
Thu, Mar 17, 2011 at 1:50:00 PM
Underground House
Mon, Aug 8, 2011 at 6:54:42 PM
underground
Fri, Sep 15, 2006 at 2:42:33 AM
Topography and Pad issues. Help needed
Mon, Sep 21, 2009 at 7:30:14 AM
Issues with Topography
Mon, Apr 18, 2005 at 1:22:57 AM
Page generation time: 1.4507
