42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Is there a way to isolate or select all the contents of a level?
Fri, Sep 12, 2014 at 6:22:19 PM | Is there a way to isolate or select all the contents of a level?
C3POjr
Is there a way to isolate or select all the contents of a single level, among multiple levels?
I am using Revit 2015.
Thanks in advance.
Mon, Sep 15, 2014 at 7:22:01 AM | Is there a way to isolate or select all the contents of a level?
You can use a 3D section box then window the view.... I would assume that you would have a way to filter out multi-level elements.
Permanently isolate object in Revit?
Tue, Jul 10, 2012 at 8:14:51 AM
Select By Level
Mon, Dec 13, 2010 at 8:40:57 AM
Editing Multiple Text Contents
Tue, Sep 30, 2008 at 10:08:07 AM
HOW TO ISOLATE A FLOOR PLAN FOR RENDERING ?
Mon, Aug 3, 2009 at 7:05:08 AM
Capabilities to isolate phases
Tue, Nov 28, 2006 at 5:43:03 AM
Page generation time: 0.7408
