51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Fatal error on a shared job Revit 2015
While working in a shared file we recently had a fatal error. We opened the recovery file and everytime we try to sync a new fatal error pops up. Anyone else had anything like this happen to them? Have you been able to fix it?
Thanks,
AAron
You saved a new local recovery. Have you audited your files when you opened them? Try that if you need to recover the local. You probably should open the central with an audit and create a new central for everyone then to work off of.
umm what is auditing?
Thanks,
AAron
First, try to follow this advice found in your HELP:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-80D390B3-D751-4703-BC79-1A66497C1928
Here is a reference on auditing:
http://help.autodesk.com/view/RVT/2014/ENU/?caas=caas/sfdcarticles/sfdcarticles/Error-Element-Element-ID-has-become-corrupt-sometime-before-this-session-when-opening-a-Revit-file.html
Thes and more information is available in your HELP. It is your best initial resource so try to use it.
24 Posts No Rating |
Belive me,, it's the worst bug of all time.. I don't know why exactly it happens but in my case when I create a 'Model in-place' wall or column or something like that ,, and after a point I try to edit the in-place model (especially walls or columns or beams,, don't ask me why.. even I don't know) and save the edit.. it will instantly pop up the 'Fatal Error' dialogue box. I make a copy of the same wall and edit and replace with the original. Sounds weird, right but that how it is on my side.
In Solidarity |
Amigos:
Una pequeña aportación. Exitos:
http://venadorevit.blogspot.com.ar/2016/03/error-fatal-revit-y-sus-modelos.html
A fatal error loading family into project overwriting existing |
Mon, Jun 22, 2015 at 8:03:38 AM
fatal error |
Wed, Aug 30, 2006 at 1:15:22 PM
Fatal error when in any type of sketch mode |
Wed, May 16, 2018 at 11:28:43 AM
Fatal Error when adding casework tag |
Mon, Apr 6, 2009 at 12:38:40 PM
Revit 2015 error: "A fatal error has occurred..." |
Thu, Oct 16, 2014 at 11:01:49 AM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
