61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sections not Showing in Plan View
Wed, Sep 10, 2014 at 11:22:29 AM | Sections not Showing in Plan View
reimerdesign
i'm using Revit 2014.
when i try to create a section or callout on a floor plan, it keeps teling me the following:
"None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
I THINK i've gone thru all of those settings, and I can't seem to find any issues with the settings anywhere... anyone have any ideas??
Wed, Sep 10, 2014 at 12:10:42 PM | Sections not Showing in Plan View
Are those two categories (sections & callouts) on in VG / annotations?
If that doesn't fix your problem, change the view scale to a much larger scale and see if they show up.  If they do, then click on one and see if they are hidden at "scales coarser than xxx"
Also - are you using phases?
Edited on: Wed, Sep 10, 2014 at 12:11:27 PM
Tue, Sep 16, 2014 at 11:26:38 AM | Sections not Showing in Plan View
reimerdesign
yes they are ON in VG/annotations.
changing view scale does nothing.
Phase Filter is set to "None"
Phase is set to "New Construction"
Tue, Sep 16, 2014 at 11:31:47 AM | Sections not Showing in Plan View
reimerdesign
I have 2 sections that I created quite some time earlier in the project that are showing in the plan views, these were created when I first started building the model... but it seems like any new sections I try to create are now invisible...
Tue, Sep 16, 2014 at 11:43:21 AM | Sections not Showing in Plan View
reimerdesign
I have tried a work-around... I created a new plan view of the same floor plan, and now if i create a new section it shows up on the plan view... strange thing though - the sections that DO show up in the original floor plan do NOT show up in my duplicate floor plan........????
ANY THOUGHTS FROM ANYONE???
Wed, Sep 17, 2014 at 8:05:33 AM | Sections not Showing in Plan View
You don't say what updates you have installed.
It appears that something is wrong in your process.  I still think phases.
Mon, Oct 28, 2019 at 4:42:03 PM | Sections not Showing in Plan View
MaxFasher
I am aware that i an digging this thread up from the dead
but i had something similar and though you all show know the solution i had.
I had to tranfer project standards from the linked file "Phase settings"
done.
Roof Plan not Showing in Site Plan
Wed, Jul 12, 2017 at 12:03:33 PM
11
section line not showing
Fri, Aug 7, 2015 at 12:06:46 PM
Wall Types - floor plan vs. elevations/sections
Fri, Apr 7, 2006 at 4:38:47 PM
Door swings not showing in plan view
Mon, May 5, 2008 at 7:27:39 PM
Roof not showing all layers of sructure in some sections
Fri, Sep 15, 2017 at 1:25:05 AM
11
Page generation time: 1.0196
