29 Users Online (28 Members):
Forums >> General Discussion >> Revit Project Management >> Linking DWG in Revit 2014
0 Posts No Rating |
Hello all,
I need your help. I'm frustrated and pulling my hair!! I have linked dwg file in Revit. When I open the dwg file in AutoCAD the building is positioned straight on the x-axis but when I link in Revit the building is positioned diagonally!! I rotated the building back to a straight position but when I dimensioned my gridlines in Revit, Revit complained about two gridlines not being parallel to each other!!
Note that even though AutoCAD showing the building straight on the x-axis, the cursor axis is pointing toward north west.
How to fix this? would AutoCAD UCS fix this problem before linking in Revit?
Thank you...
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Autocad origins and Revit's are never the same. Watch this video.
http://www.youtube.com/watch?v=BigvY4LT-RI
0 Posts No Rating |
Thank you for your reply.
I have tried other cad drawings and they show just fine in revit!!
How interesting - you obviously learned nothing from the video.
0 Posts No Rating |
I haven't watched the video yet. I was just adding to the discussion that other cad drawings showing just fine in revit.
Thanks,
DWG linking into revit |
Mon, Jun 9, 2014 at 7:11:38 AM
Problems linking DWG CAD files into Revit |
Wed, May 14, 2014 at 10:33:52 AM
linking dwg files in elevations |
Wed, Nov 23, 2005 at 3:04:32 PM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP |
Thu, Aug 26, 2010 at 7:48:24 AM
Problem Linking DWG Files Showing Rebar as Polyline |
Tue, Jan 22, 2008 at 11:07:56 AM
Members: | 2026126 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
