76 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 - Stairs double cut line in plan
Mon, Sep 8, 2014 at 4:28:26 PM | Revit 2014 - Stairs double cut line in plan
motodesign
Maybe I'm missing something-  I have a multi story stair.
In plan, I want to show a double cut line with the stair lines inbetween the cut/break lines not to show.  But they still show.
This doesn't seem right to me, and I've seen examples on the web where this works.  When I read on how to do it, everything just says to turn on double cut line.  I got that covered, both cut lines are showing, but the interior part beteen the cuts isn't makes out.
What am I doing wrong?
Thanks!
Tue, Sep 9, 2014 at 7:35:48 AM | Revit 2014 - Stairs double cut line in plan
Turn off your underlay
Tue, Sep 9, 2014 at 10:59:44 AM | Revit 2014 - Stairs double cut line in plan
motodesign
no underlay on.
I've noticed that it does with work with a string of multistory stairs, but if the stairs aren't multistory, copied above each other isntead, it does not work. At least, I can't get it to work.
Also, the built in stair arrow tool doesn't work very well either, the line/arrow goes past the break line
Tue, Sep 9, 2014 at 11:14:47 AM | Revit 2014 - Stairs double cut line in plan
I wish you had said they were seperate stairs.  Obviously, the cut setting for one stair will not affect another.  You will have to do these seperately.
We don't ever use the built-in arrow.
Stair Cut Line : Double Line
Mon, May 18, 2015 at 3:19:09 AM
Stairs and plan regions (cut height)
Mon, Apr 21, 2014 at 10:22:58 AM
Stair Cut Lines
Sun, Nov 6, 2011 at 8:43:09 AM
Ramp won't show cut in plan view...
Mon, Mar 3, 2008 at 4:19:05 PM
Double Landing Stairs on single level
Mon, Mar 8, 2010 at 10:02:04 AM
Page generation time: 20.0351
