87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Beams in 3D view shows only one line, not the whole volume !
Mon, Sep 8, 2014 at 11:42:52 AM | Beams in 3D view shows only one line, not the whole volume !
Balitog
Beams only showing in shaded mode, Is this controlable to be able to see in hidden lines mode also?
Mon, Sep 8, 2014 at 12:13:25 PM | Beams in 3D view shows only one line, not the whole volume !
I see beams in both views.
Beam visibility is dependent on VG settings.
NOTE:  In the hidden line view, it appears that your floor beams have curved corners.  Don't expect a line at the curve.  Also, they don't join or end at the back beam.
Revit Architecture 2012 - Section shows view from behind cut line
Thu, Jan 10, 2013 at 12:38:21 PM
BEAMS IN COARSE VIEW PRINTING OUT AS CONTINUOS LINE
Mon, Sep 8, 2014 at 12:26:44 PM
structural framing vs scheduling (volume report)
Fri, Feb 25, 2005 at 11:15:13 AM
Visual Style of Beams in Plan View
Thu, May 22, 2014 at 4:01:04 PM
RAC 2012 - Structural Section View shows as Wireframe vs. Hidden Line
Wed, Mar 7, 2012 at 1:50:32 PM
Page generation time: 2.3837
