64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> trapezoidal shaped curtain system????
Tue, Mar 7, 2006 at 6:38:58 PM | trapezoidal shaped curtain system????
cgebhart
How can I make the curtain grid non-orthagonal with the edges of a curtain wall?? Thanks
Tue, Apr 4, 2006 at 3:31:00 AM | RE: trapezoidal shaped curtain system????
MikeChan
3 Stars: 5 Votes
It is depended on the geometry of the buildng you are creating. If the curtain wall your creating is vertical, but you want to have some diagonal mullion, I will suggest you create 2 curatin wall systems place them in the same position, one go to one direction and the other one go to and other direction, and disable one of the curtain wall system is not room boundary, just to keep the room tag function correctly. However, if the cutain wall you are creating is not vertical, then you have to the trick in the curtain wall panel family, just do an extra extruction pretent to be a mullion. I think that willl do in most situation.
Thu, Apr 13, 2006 at 5:03:41 PM | RE: trapezoidal shaped curtain system????
wcrane
It seem like you should be able to do this but i guess not. You could create a ruled curtain system based on lines. each horizontal section would be a separate system. then apply only one mullion where they butt eachother.
Fri, Apr 14, 2006 at 1:17:54 PM | RE: trapezoidal shaped curtain system????
wcrane
I created one using the curtain system. i made a video how-to but is 2.5mb. attached an image. Post edited on 2006-04-14 13:18:14
Curtain Grid Problems [ 1 2 ]
Wed, Apr 10, 2013 at 5:57:46 AM
19
customerized curtain panel doesn't work with the irreglar shaped panel?
Sat, Jul 10, 2010 at 1:48:43 PM
Curtain System on a double curve
Wed, Jun 20, 2012 at 9:13:34 AM
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:48 PM
Curtain system from mass - Revit 2014
Fri, Jun 17, 2016 at 12:20:50 PM
Page generation time: 1.4232
