Forums >> General Discussion >> Revit Project Management >> Revit Keynote
0 Posts No Rating |
Hi All, just want some feedback on what people use Keynotes for in general? Updating the office system, and want to use keynote more effectively. I've only ever used keynote for demolition works on the drawings... any other effective areas that can improve the project management process?
Thanks
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
I really like keynotes because they are uniform across the project. You can use keynote tags with a keynote legend or you can use text keynotes. In many cases, we prefer the text.
We also use different tag shapes for different keynotes. Architectural - demolition - toilet accessories. Obviously, we filter the keynote legend accordingly and have this symbol in the associated keynote legend.
Edited on: Fri, Sep 5, 2014 at 7:18:47 AM
![5 Stars: 5 Votes](/images/stars_5.gif) |
We are using keynotes for noting the FF&E (Furniture, Fixture & Equipment).
Some of our projects require FF&E plans and schedules.
Each FF&E family has shared parameters, with customized FF&E Keynote Tag, and FF&E Keynotes.txt file per CSI format.
We can place all FF&E on the plan, then click Keynotes in Annotation Tab, just hovering the cursor on top of that furniture, then a "ghost" keynote will be shown, then just click and place the keynote. No typing required, and all FF&E will have the keynotes to match our master FF&E list. Then a FF&E schedule can be populated with all information, such as manufacturer, model number, description and quantity.
0 Posts No Rating |
Hi, I am new revit city, can anybosy tell how to write new post in revit city?
or answer my query
I have drawn a multiple story building in revit, but when i go to elevation view i cant find the elevation although there is levels line....can anybody helps?
Ali
Log on, go to "Forums", select topic, for example, "Community", click "Newbies",at the top, click "Start New Thread". Post your questions, then just click "Submit" on the very bottom.
That's it.
And welcome to the RevitCity!
Edited on: Sat, Sep 6, 2014 at 9:43:22 PM
keynote categories |
Fri, Aug 10, 2012 at 3:56:23 PM
Multiline keynote |
Thu, Jan 8, 2009 at 2:31:33 PM
Keynote Legend Not Showing Keynote Text |
Fri, Sep 6, 2013 at 11:40:59 AM
12
Keynote Text in Schedules |
Thu, Sep 11, 2014 at 4:45:04 PM
Material Keynote not working on window family |
Tue, Nov 26, 2013 at 3:47:40 PM
Members: | 2026126 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
