90 Users Online (88 Members):
Forums >> Revit Building >> Technical Support >> sign board with logo
Hi, I've been working on a commercial project and I want to include different sign boards with company's logos on the facade. I have the sign boards modeled in Sketchup and I exported them to revit using the In Place Mass tool, up to there everything is just fine, the problem is that I want to add materials to the sign boards (when I make a render it looks grey and without any material). Is there a way to add materials to a mass? also I want to add different colors to the same mass, is it possible?
I don't understand why you would use the mass tool. << Where did you see something to point you in this direction?
Import into a family set to the correct category. The materials will be assigned by layer and you can reassign them in the family or within the project.
logo or sign on a wall |
Mon, Jun 11, 2007 at 8:00:02 PM
URGENT! blue logo revit 2012 |
Fri, Jun 14, 2013 at 9:45:05 AM
Logo / Filled region in Drawing Sheet |
Fri, May 7, 2010 at 4:22:30 PM
ADA Sign - Text not showing |
Tue, Sep 24, 2019 at 4:03:48 PM
Logo on a Titleblock showing up in negative |
Wed, Oct 31, 2012 at 7:49:50 AM
Members: | 2022461 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
