52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> missing layers in the exported cad
Mon, Sep 1, 2014 at 7:52:41 AM | missing layers in the exported cad
warunya049
Hello, I'm using 2014 Revit and have some problem with the exported AutoCAD from Revit.Some finish of column doesn't show in AutoCAD. The column is Structure column and finish is 20mm wall. How can i fix this problem?
Tue, Sep 2, 2014 at 1:07:42 PM | missing layers in the exported cad
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Try changing the 20mm wall type in REVIT. I see that it's the only wall thats green (material) so try making the 20mm wall by duplicating a wall that does show up but make it skinnier.
Dimensions missing from the exported cad drawings
Fri, Jun 6, 2008 at 2:47:31 AM
import cad to revit - missing layers in revit
Tue, Sep 8, 2015 at 11:11:15 AM
Imported layers still active when exporting
Fri, Feb 26, 2010 at 8:44:41 AM
Link Cad issues
Tue, Aug 5, 2014 at 11:28:04 AM
Importing some CAD layers then wanted to import some more...
Tue, Jan 2, 2007 at 12:19:54 AM
Page generation time: 0.4717
