40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 - Array within Profile Family
Fri, Aug 29, 2014 at 6:39:13 AM | Revit 2014 - Array within Profile Family
SB84
Hi,
I want to use an array (with associated parameter) within a profile family (Metric Profile Reveal). The profile will be used for wall reveals. I have a profile used in metal cladding (eg trapezoidal) so I want to be able to create a profile family where you can control the number of instances of the metal profile. The family works fine when editting the family itself - but when imported into a project it doesn't work and asks you to check that all lines are in closed loops. I think because the array makes groups it doesn't 'join' the lines although they are actually end to end. I have a feeling that the answer to this is that you can't do it - but has anyone had any success with this or found a workaround?
The alternative is to make one oversized reveal profile that is well above the height of any wall we're likely to model. I have a family that sizes the profile to an actual panel size so they can be dimensioned but these don't work every well when you add them to the structure of a wall.
Thanks
Fri, Aug 29, 2014 at 7:17:08 AM | Revit 2014 - Array within Profile Family
A profile family must be 1 (one) closed loop.
Fri, Aug 29, 2014 at 7:25:02 AM | Revit 2014 - Array within Profile Family
SB84
Thtat's the thing.. it is one continuous loop - but I think when you use an array Revit reads each group that it forms as separate to the next one even though the lines appear joined.
Fri, Aug 29, 2014 at 7:34:25 AM | Revit 2014 - Array within Profile Family
Ah come on, an array is NOT ONE!!!!
Fri, Aug 29, 2014 at 7:47:13 AM | Revit 2014 - Array within Profile Family
SB84
When it is like this then it is ONE LOOP.. I'm not trying to array the whole thing to have multiples ie. more than ONE loop- trying to array part of it within the loop. See attached image.
This isn't working as Revit doesn't read each group in the array as being joined - even though they are physically. But was wondering if there was another way to achieve the same thing?
Fri, Aug 29, 2014 at 8:59:24 AM | Revit 2014 - Array within Profile Family
Why array it at all?  Just copy multiple and quit messing with it.
Fri, Aug 29, 2014 at 9:35:43 AM | Revit 2014 - Array within Profile Family
SB84
I wanted it to be parametric. I'll find an alternative solution.
Thanks for your input.
Array Parameter within Family
Thu, Aug 7, 2014 at 8:25:10 AM
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:29:38 AM
Resizeable array components
Thu, Jul 17, 2014 at 2:43:47 PM
Radial Array in a Family
Mon, Apr 11, 2005 at 8:56:13 PM
Array in Revit families in shocking!!!
Mon, Jan 23, 2012 at 9:53:09 AM
Page generation time: 2.1745
