28 Users Online (26 Members):
Forums >> Revit Structure >> Technical Support >> Compound beams
Let say i have a concrete beam that 48/36x40. Incase you dont understand what im getting at. The beam stars out as 48w, but ends up being 36w due to an opening or something. I can i create a family that will give me this flexiblity?
Also i want it so it well appear 48/36x40 in my live schedule.
Edited on: Thu, Aug 28, 2014 at 8:08:50 AM
hi,
i know its a bit late for reply, but just to answer your question...
yes you can achieve this, you can reference to your HELP how to use sweep and sweep blend.
for the schedule, if you want to schedule any of your parameter, you should use SHARED PARAMETER (refer to your HELP)
but if you want just "48/36x40". you can use this name as your TYPE NAME, and schedule it...
ty
Na your not late, ill give that a try to see if i can get it working.
thanks.
Not the best, but it will do for now.
It was done in release 2013
Your thoughts on it?
non compound wall acting like compound wall |
Mon, Feb 20, 2012 at 2:30:22 PM
Compound wall |
Tue, Apr 10, 2007 at 1:10:14 PM
Doors/Windows in Compound Surfaces |
Wed, May 31, 2006 at 10:06:21 AM
Real compound walls |
Sun, Feb 20, 2005 at 8:26:42 PM
Invalid compound structure. |
Mon, Jul 31, 2006 at 4:28:11 PM
Members: | 2037276 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
