Forums >> General Discussion >> Revit Project Management >> Basic wall + Curtain wall
hello everyone. I have made a mass and then wall by face on basic wall and curtain system. I guess you can see the problem below:
I think you need to tell us a whole lot more.
First, understand that wall by face should always be your last method choice. Only use that when you can't use normal walls.
Is this curtain wall sloped and it the wall by face? It appears to be.
Is the solid wall a normal wall? Again, it appears to be.
Did you expect these two walls to automatically join? They won't. If the solid wall is normal and vertical, then sketch its profile. Because the CW appears to be connected at an angle in plan, you may have to add an in-place void seep to cut the end face.
I don't know where that angled mullion came from. Can you explain that?
both of them are sloped. both of them are default wall an courtain. I don't know how to make void on wall
I found it. thank you for help middle miulions are vertical, only side one is by face and sloped
Edited on: Fri, Aug 22, 2014 at 1:28:39 PM
Read in your HELP: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-68DBFA52-DF77-4B3F-84AC-F20194FADC64
Set the in-place void to the wall category and before finishing - pick the wall to be cut.
Basic Wall as Curtain Wall panel transparency incorrect. |
Wed, Nov 23, 2011 at 9:37:16 PM
How to make a slanted curtain wall? |
Thu, Apr 24, 2014 at 3:35:15 AM
Curtain Wall Panel to Curtain Wall Door |
Curtain wall not cutting through moulding |
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
Members: | 2119228 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
