Forums >> Revit Building >> Technical Support >> doing a night rendering
i wanted to know how to do a night rendering.
1 Posts No Rating |
although ive never done a night rendering, I noticed that when you have your frame and everything set up, you can go to the browser bar under rendering and there is an option that says Lighting... with a light bulb beside it, anyway, if you go into this, you wil have a light source called sun, to the right of that is a box with a check mark in it. im guessing that if you uncheck the box, it will turn the sun off, creating a night scene. but ill asume that you will need to put in lamps and such for the rendering to work
yea i have all the lights i want, but when i click go, and wait, the scene is still all black, and i made sure the lights were on.
please explain your setup in detail.... lights are placed where, how many sources, is your sun turned on or off and most importantly, have you checked the envirnoment setting. I need to know your initial setup and i can probably help you from there.....
well i got now. thaks for the help
7 Posts No Rating |
I'm having the same problem. Can you post your solution?
all did was that i turned the sun off and turned on all the lights i had.
3 Posts No Rating |
Or you can go to Advanced Model Graphics ans turn the sun to a brightness of zero. It will render all black, and then you have to adjust the exposure accordingly....Hope this helps
How to render with night mode on revit architecture 2011 |
Mon, Dec 5, 2011 at 3:42:42 PM
Revit to 3ds night render |
Thu, Jul 30, 2009 at 1:26:03 PM
revit night rendering |
Wed, Jul 20, 2011 at 11:47:03 AM
Night Scene Render |
Wed, May 2, 2007 at 9:21:19 PM
night rendering in 2012 |
Mon, Apr 23, 2012 at 2:56:20 PM
Members: | 2100572 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
