61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Raking curtain walls, adding tags to Shop Front glazing
33 Posts No Rating |
I need to know if anyone knows of a quick way to do curtain walls that rake vertically. At present, I'm using the "Curtain System by Lines" command. This has been a little time consuming as I've needed to draw model lines at the required levels and offsets for the base and head. I then create the curtain wall. If any changes to the building height happen, the wall does not adjust with it. Can this be recified? Is there a quicker way to construct them?
Also, the building I'm currently documenting has heaps of shopfront type glazing, I need to apply tags to this glazing and be able to add to the window schedule, is this possible? Any help will be greatly appreciated.
GN Brisbane, Q Australia |
Use a mass then create curtain wall by face. Then if the height changes, adjust the mass and select the recreate option on the curtain wall and it will automatically update to the height change.
To tag the panels as windows, swap them out for curtain wall windows.
HTH.
Post edited on 2006-03-07 01:13:08
Hey, Mr Spot we're practically neighbours. Thanks for you quick response, I'll try what you said.
Curtain wall shop front |
Fri, Apr 3, 2020 at 2:42:51 PM
Glazing in curtain walls |
Thu, Dec 10, 2015 at 7:38:15 AM
Curtain system > glazing panel matherial |
Mon, May 28, 2012 at 1:02:14 PM
Glazing in roof |
Wed, Oct 17, 2007 at 5:52:52 PM
Curtain Wall scheduling |
Mon, Feb 7, 2011 at 12:36:05 PM
Members: | 2022277 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
