43 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2012: Warning Error in a project "HELP"
Thu, Aug 14, 2014 at 6:00:36 AM | Revit 2012: Warning Error in a project "HELP"
pwolf2142
I've been creating my families and some of my families download into a project then others will not.  I get the following warning "Couldn't find an appropriate Host. Try Selecting a different Host Face or Switch Placement Mode."  What is this warning all about and how do I fix this so once I but my families out online for others to use they will work for them?  I need to get this resolved ASAP
Thu, Aug 14, 2014 at 7:11:53 AM | Revit 2012: Warning Error in a project "HELP"
This may help you understand:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-7B632B85-BB40-4935-B31E-EF829832EEB0
Look on your ribbon when this occurs and you will see an option to change placement faces.
Fri, Aug 15, 2014 at 9:25:47 AM | Revit 2012: Warning Error in a project "HELP"
pwolf2142
This did not help, there is nothing I can do to the plane once I try to load it into the project.  What is causing this to pop up on some of my families and not all of them.
Fri, Aug 15, 2014 at 9:37:16 AM | Revit 2012: Warning Error in a project "HELP"
Our problem is you don't tell us enough for us to give you a complete answer.
Your families are obviously built as hosted.  Hosted to what?  A floor, a level, a wall, a ceiling, a face, a work plane based?   You built them - not us.  Are you working in the correct view to place these objects?  For example, a ceiling hosted element typically can't find a ceiling while your in a floor plan view.
Every view has a work plane but that can be changed by the user as he works.  Are you doing this?
Are the hosted element category turned on in the view you are working in?  You sure can't place a floor hosted element when there is no floor.
Fri, Aug 15, 2014 at 11:13:59 AM | Revit 2012: Warning Error in a project "HELP"
pwolf2142
I created all my families from the floor level up.  I do change the plane that i'm working from.  Do I need to change them back to what it was after i'm finished with the model?  I am new at using Revit so please help with whatever as I have over 500 models created and 25% of them won't go into a project.
Fri, Aug 15, 2014 at 11:14:03 AM | Revit 2012: Warning Error in a project "HELP"
pwolf2142
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
"Please enter Value less than 9144000mm" Why????? Project base point issue
Fri, Sep 23, 2011 at 11:22:05 AM
Project Sharing Warning Message exceeded "Number of People"
Thu, Dec 3, 2015 at 7:01:51 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
"Cant Make Door" Warning
Thu, Oct 23, 2014 at 2:45:09 PM
Page generation time: 2.8810
