52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Extending an exterior finish on a wall
15 Posts No Rating |
I am looking for a way to extend the exterior finish of a first story wall up over the second story wall, without having to adjust the materials of that second story wall. For example, I have siding on a CMU wall on the first story, and I want to cover the floor system and second story frame wall with that siding as well.
I have seen this done before on a video fron AU online, but I can't remember how to do it. Any suggestions?
4 Posts No Rating |
The finish of the Wall section should be unlocked from the Wall properties, then you will be able to adjust just the finish without extending the entire wall to the second story.
The help file gives more detailed instructions, I think.
Hope this helps!
SL
exterior finish error |
Tue, Jun 16, 2009 at 1:22:12 PM
Exterior walls |
Sat, Jun 16, 2007 at 10:59:39 AM
exterior finsh below zero |
Sun, Apr 11, 2010 at 10:13:36 AM
Exterior finish on wall not exterior enough... ? |
Fri, Jun 3, 2011 at 8:44:28 PM
WALL SHEATHING AND EXTERIOR FINISH |
Mon, Jun 19, 2006 at 10:05:55 AM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
