Forums >> General Discussion >> Revit Project Management >> Controlling a Family Length by Multiples of 8'
I am trying to create a Scaffolding family and have everything working properly as long as I use dimensions of 8' in length. How can I create a parameter to restrict the length to be only multiples of 8? PLEASE HELP!
Does anyone know how I can solve this problem!? I really need some help please!
Always pay attention to the similar threads shown below. I believe the "line based family" post will show you the answer to your question.
Thanks for the response. I have seen this thread and used this formula to control the minimum length value but I still need to figure out how to allow the length to only be 8', 16', 24', ect..
Edited on: Mon, Aug 11, 2014 at 8:38:26 AM
Divide by 8 then Subtract 0.5 and round up.
Does this formula go with the length or the array parameter? also I am getting an "Inconsistent Units" error with this formula.
Sorry for not understanding, still learning here...
You do have to pay attention to units. I would assume your imput is distance which, if you look at in decimal feet, you would divide by 8 and you may get a fraction. The subtract - roundup function will get you a whole number which you need to change to an integer for your array.
Controlling Length of Floor Based Generic Model |
Tue, Jan 4, 2011 at 12:11:58 PM
windows-multiples |
Fri, Feb 24, 2006 at 2:16:11 PM
How to make family length visible in project |
Tue, Nov 14, 2017 at 2:53:03 AM
line based family help (length) |
Wed, Aug 6, 2014 at 9:15:36 AM
Creating a Beam Family Where Each Type has a Determined Length |
Wed, Aug 31, 2016 at 11:55:27 AM
11
Members: | 2101398 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
