Forums >> Revit Building >> Technical Support >> linework tool - original showing up next time I open revit project
I have window elevations where I hide the casing (trim) around the window with the linkwork tool using <invinsible> lines. and it seems as though next next I have to open the project the lines that I hide with the linework tool have reverted back.
I have never seen that happen.
Remember, the linework tool is 2D and view dependent. ONLY the view it was used in. Also, you may have multiple elements in the same place. Typically you will make the one invisible and then the next one shows. NOTE - If you change the view depth, other elements may show up in the same place.
I havent changed a thing relating to the view. I will use the linework tool and save & close and the next time I open the project the lines are back from being invisible
SInce you have not shared what Revit and what updates you have installed, you have probably wasted some time. This is probably an update issue.
sorry,
I am in Revit 2015 and have the latest update release 3
Create the smallest file you can with a wall and the window in it - purge and compress then test to see if you still have the problem. If so, then post the file so we can look at it.
Linework tool issue |
Mon, Sep 26, 2011 at 3:20:45 PM
linework tool - showing through? |
Thu, Nov 16, 2006 at 4:20:56 PM
Revit 2014 - floor transparency and the linework tool |
Thu, Jan 9, 2014 at 10:38:53 AM
Linework Tool (LW) |
Thu, Mar 11, 2010 at 4:34:31 PM
Using the Grid tool Crashes Revit every time |
Tue, Dec 23, 2008 at 11:47:57 AM
Members: | 2115617 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
