69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Defining elevation views parallel to a reference plane
Sun, Mar 5, 2006 at 1:45:09 PM | Defining elevation views parallel to a reference plane
ncazanav
I learned something very useful in the tutorial by Mr Spot (thanks a million!!!) which is how to define a elevation view parallel to a reference plane by going to View->New->Framing Elevation, and picking a reference plane as the reference. However the option framing elevation is only enabled when a plan view is active, so any framing elevation is defined relatively to a reference plane drawed in a plan view. How can I do this in a elevation view ? If I draw a leaning ref plane in a elevation view how can i define a new elevation view relative to it ?
Sun, Mar 5, 2006 at 2:37:41 PM | RE: Defining elevation views parallel to a reference plane
ncazanav
Ok I've found a way to do what I wanted, it is to define a section view which can be parallel to any reference plane no matter the angle in X/y/z axis... Is it the way it has to be done?
Importing Cad to a specific reference plane
Fri, Mar 14, 2014 at 1:46:30 PM
Dimensioning 2 non-parallel reference lines
Thu, Feb 14, 2008 at 9:40:47 AM
Floors - Constant-height-defining lines must be parallel??
Tue, Aug 29, 2006 at 12:38:25 AM
reference plane depth/height
Wed, Jul 7, 2010 at 3:11:31 PM
Multi-view Elevation - Reference SIM
Fri, Mar 9, 2012 at 8:40:42 AM
Page generation time: 0.9152
