Forums >> Revit Building >> Technical Support >> 1 hour practical Revit test at interview
I might be invited for an interview with the practical test (not a question test).
I know that this company is big, and in similar tests they asked to make a mass, mass floors, more than 10 levels, put walls and windows, make a rendering and organiza all this staff on a sheet.
What else could they ask to do in one hour? Rooms? Room or area legends? Schedules?
How creative can I be in this test?
I would be glad to hear any suggestions and opinions.
Thanks.
I don't use a lot of massing and I never have with revit so this must be a lot of different designing going on in this firm. 1 hour is not a lot of time to complete all of this so I am not sure what else they would ask. a practical test for me would be drawing floors, walls, windows doors etc, creating a schedule perhaps. I took a 15 minute test for my current job and it is not a lot of time at all especially when you don't know their revit layout. Good Luck!
24 Posts No Rating |
Worksharing, Design options, parametric family(s), schedules (VVIMP). It totally depends on the kind of projects they are dealing with right now. It it's all about high-rise buildings then yes, Mass, Adaptive points (maybe, not sure).. a firm like Perkins+Will or SHoP will definately ask about that. I was asked in my interview, I told them I have theoritical knowledge of how it works but never got a chance to do it. That's a fact btw.. Back then, I didn't have a super computer or a REVIT program to practice with
In Solidarity |
Thanks a lot for the support (practical and moral). It's very important for me now.
I will try to practice.
Phases and Phase Filters also.
Thanks. I am OK with phases - worked a lot with renovations.
Interestingly, for some Revit students it is the most difficult topic (of Revit fundamentals). When I exp;ained this, I "played" with them in "Back to the Future " film. It helped.
But in my case, I suspect, moght be also curtain walls and families.
Where in standard libraries are Curtain wall profiles? I cannot find them.
Profiles > Curtain Wall Profiles ... also check Mullions > Railings etcc.. I don't rem the exact location.
With Phases,,, there is always something new you don't know. It is a Pandora's box of Troubles !!!
In Solidarity |
I checked there - in Profiles, Curtain walls... Did not found. I downloaded 3 curtain wall profiles from RevitCity, but the software says that they are not of the required kind. Where else can I find these mullions?
Hi Glenlake,
Here was the thread you asked before. That should answer your curtain wall profile question.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=30342
Hope that was it. You also can create your own from any profile family template.
Good luck!
Thank you very much.
I worked with these curtain walls just once, long time ago, and still do not understand how it works. Tried everything what people recommended, but, probably only practice could help. Hope, R 17- R 20 will simplify this thing. And will make a slanted wall type available for us as well.
Again, deep gratitude for all who helped me during all this time.
Interview Questions |
Wed, May 16, 2007 at 12:31:48 PM
Assessment test for a Revit coordinator? |
Wed, Jul 29, 2009 at 9:52:23 AM
The CGschool announces five free 1-hour webinars |
Sat, Oct 30, 2010 at 9:56:09 AM
Trees can't be rendered? |
Mon, Aug 25, 2008 at 3:14:44 AM
Newbie Questions: Revit 7.0 with Autodesk Viz 4 or VIZ Render 2006 |
Wed, Feb 22, 2006 at 4:09:01 AM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
