132 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Pad Phasing
Wed, Aug 6, 2014 at 4:01:38 PM | Pad Phasing
quinn
We have a pad set to a future phase and we placed it onto an existing topo.  The existing phase is showing a hole where the pad of the future phase will be.  The pad doesnt exist yet so how can the existing phase show where it will be?
Wed, Aug 6, 2014 at 4:21:55 PM | Pad Phasing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Sounds like you have your phase filters set wrong.
Wed, Aug 6, 2014 at 6:17:50 PM | Pad Phasing
quinn
Views we reviewed were previous and new and show all and we had the issue.  What is wrong in our phase filters?
Thu, Aug 7, 2014 at 1:01:53 AM | Pad Phasing
ronmalit
5 Stars: 3 Votes
nothing wrong with the phase
its just TOPO behaves like that as far as i know (rvt2013)
even if its filter off.. the cut will still be there.
"if you create a phase before any pads were added the toposurface will still display the opening"
http://forums.autodesk.com/t5/Revit-Architecture/Building-pads-don-t-seem-to-respect-phases/m-p/2902292#M49577
Thu, Aug 7, 2014 at 7:05:47 AM | Pad Phasing
3.5 Stars: 395 Votes
roomalt is correct.
I would probably use either worksets or design options to have two different topos.
Thu, Aug 7, 2014 at 10:27:05 AM | Pad Phasing
quinn
To fill the void we copied the topo set one to existing and demoed it in the future phase.  The second topo in the future we put the pad on.  Both existing and future reflected what we wanted.  The first topo essentually was to fill the void in existing phase with a pad on it and it worked.
Fri, Aug 8, 2014 at 6:56:45 AM | Pad Phasing
Sofus
1 Stars: 1 Votes
I think you should use the buildin option for this, Graded Region in Massing&Site tab.
Create Existing Topo, use Graded Region, it creates a New Construction Topo (and demolishes the Existing), and gives you quantities for Cut/fill.
Sofus
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
Cannot choose edge of a pad in Revit 2010
Sun, Feb 21, 2010 at 5:16:33 AM
Topo slopped pad (parking lot/road)
Mon, Aug 24, 2009 at 8:26:23 AM
Phasing - Building Already Done but Dind't Set up Phasing
Tue, Dec 15, 2009 at 7:40:42 AM
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:01:59 PM
Page generation time: 0.2853
