60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Duplicating Views
Sat, Mar 4, 2006 at 4:19:37 PM | Duplicating Views
Steve1959
Not sure how to create a duplicate of the floor plan so I can delete and add items without altering the original. Want to create a bracing plan using the original. Using the visibility tools are not ideal. Is there another method. Many Thanks in advance! I would be lost without your help. (especially you Briso Guys) Regards Steve
Sat, Mar 4, 2006 at 4:40:34 PM | RE: Duplicating Views
JAIMERIOSJR
Right click on the floor plan at the project Browser (second window from left to right) click either "DUPLICATE OR DUPLICATE WITH DETAILS" if you select "duplicate wth Details" you will be able o turn off (eliminte without erasing) the details you do no want to see. In addition you could use the phases to automatically show or remove elements that are related to the phase or phase combination filtering. I hope this helps you
duplicating views without duplilcating callouts or view tags
Wed, Sep 11, 2013 at 3:09:16 PM
Duplicating Views
Wed, Jun 8, 2011 at 5:34:24 PM
Duplicating views and phasing Question
Mon, Jun 28, 2010 at 7:18:38 AM
views and sheets for revisions [ 1 2 ]
Fri, Mar 11, 2011 at 9:21:40 AM
20
Duplicating a floor plan and Creating a new floor plan
Wed, Feb 3, 2016 at 7:28:17 AM
Page generation time: 0.4506
