82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Adjusting the building workplane so that it orients to site bearing.
Tue, Aug 5, 2014 at 12:46:14 AM | Adjusting the building workplane so that it orients to site bearing.
JohnCullen
I am trying to adjust the global workplane bearing of my building model to match site geometry. At the moment when I draw a recangle its edges are not perpendicular/parrallel with the site boundary which is about 15degrees off true North/south bearing. I have been able to create a workplane, but not set one that will work in all views. Will be greatful for help.
Tue, Aug 5, 2014 at 7:23:49 AM | Adjusting the building workplane so that it orients to site bearing.
I think you need to show us what you are talking about because your process may not be necessary.
Do you understand that you can rotate any view?  Then you can work orthographically in that view.  It is best to use a rotated working vies as I have done.
Tilt Building Bearing Pockets
Tue, Jun 8, 2010 at 2:51:41 PM
Linking Building to site
Mon, Jan 5, 2009 at 1:41:36 PM
Cut Planes for CMU Bearing Wall Systems
Thu, Jun 4, 2009 at 6:08:28 PM
Moving Building up with out moving the site
Sun, Jul 31, 2016 at 5:20:10 PM
Imported Site into Building Model issue
Fri, Jun 27, 2008 at 11:11:54 AM
Page generation time: 10.2559
